How do I remove the Symphony Premium?
How do I remove this icon from my screen? I do not use it and its not installed but I can’t get rid of it.
I tried unchecking under display options and go back and its still checked.
Install it and then you can remove it from your screen. This is not a new bug.
Thanks that worked. This should be fixed, you should not need to install and app just to hide it. :slight_smile:
I believe this to be intentional due to what looks like a partnership or promotion by Symphony.
