There are no options when I am using the optical output to turn off software volume control. It is available over USB but not optical. When I touch the gear to the left of the optical out I am only given three lines of adjustment. The other units I have seen in stores have 5 lines and the 4th is software volume control. That line doesn’t exist on my 250.
Software up to date???
On my RS520 (5.7.07)
Software is up to date.
The functions in the RoseConnect app and the functions in the RS201 are not displayed the same.
However, they are not there in some places and are there in others, but if you set them up, they will be linked.
