I have RS130, AES to my DAC, and I use the HDMI to my TV and it works as you mentioned: Video goes to the TV and audio goes to DAC. I never enabled the HDMI out (I just checked and it is not enabled). I would suggest disabling the HDMI out and checking the result.
What HDMI settings are you trying to change?
Thanks to both for the suggestions. I was doing exactly as you said but still got the errors from the 130.
I moved the hdmi cable to hdmi 1 on the tv and reset the 130. then things started to work as expected.
although I needed to reduce the hdmi resolution on the 130 to 1080p even though the tv is 4k.
I will leave it alone for now as it is also mirroring want is on the 130 screen which is a nice surprise. I thought it only showed the rosetube videos.
thanks again for the help and quick replies! It is the community like this that makes these bleeding edge gadgets worth sticking with!
another update. I used the same cheap hdmi cable but needed to change a setting on the tv. It was an hdmi setting from auto to enhanced. this allowed me to change the display/hdmi settings to 4K.
I’ve got the 130 and the 160 . I want to watch Netflix from tv and hear it through the amp and my speakers.. but can’t seem to get it to do this. Does this actually work… thanks
