I have a playlist with over 300 songs, created with “RoseConnect One,” but they don’t appear in the playlist on my Rose 520. I can only see a few, not all of them. Is there some limitation? Or am I doing something wrong?
Could you please check a few things for us?
- In the playlist that contains more than 300 songs, what types of content are included? For example, are they from Qobuz, TIDAL, USB-stored music files, or RoseTube videos?
- In the ROSE Connect ONE app, can you see all of the songs in that playlist, or are only some of them displayed there as well?
- We tested adding 600 songs to a playlist on our side, and all songs were added and displayed normally.
Before entering the playlist on your RS520, the total number of songs should be displayed next to the playlist name. Is that number shown correctly on your device?
We would like to reproduce the issue in an environment similar to yours, so we would appreciate it if you could provide detailed answers to the questions above.
Hi! about your questions:
1.- All the songs are from USB-stored music files (SSD-Samsung)
2.- Yes, In the ROSE Connect ONE app. I can see all the songs in that playlist
3.- Is that number shown correctly on your device? No, no song number is displayed.
I’ve attached 3 images, the first one of the app and the next two of the device
This issue has already been forwarded to our software team.
If we are able to reproduce behavior similar to what you described, we will do our best to resolve the issue as quickly as possible.
