How to add cover after use RSA780 ripping CD?
Hi, when i used RSA780 ripping CD, some CD cannot add cover by my rose RS250, may be some CD too new or new old. May i added album cover later?
But, as i know, i searched in Rose forum, u told us Rose system cannot support this function (added album cover later), what should i do?
thanks a lot
Hello @digikitmacau
Before I answer to your question, I have few things to check
  1. Before ripping, take a picture of the screen (Disk ID) and please send it to me.
  2. Did you rip the image that entered the ripping screen for the first time? Or did you manually search for it?
  3. Are there any photo files in the folder after ripping?
There is no way to add album covers on Rose devices.
However, there is a way to add an album cover by connecting a storage device to a PC.
