How to choose between RS151 and Matrix NT-1?
Matrix NT-1 is a pure digital player, and there is also a more advanced digital decoding all-in-one machine MS-1, but the price is relatively expensive. The advantage of this Chinese brand lies in its excellent software and control, rich interface expansion, and relatively high sound quality.
I really like the appearance of the RS151 and its standard full-size body, but I feel that the software system may not be perfect. I would like to hear about your user experience.
Matrix-Audio-TT-1-achterkant MatrixAudioNT1inside_1600x_f6183985-b5f8-42c9-bc44-0e6f4b3437f7_1200x1200
Has everyone upgraded to Rose’s new firmware update? What are the differences in usage compared to the previous version of the firmware?
Matrix is a good brand… at least it has a good rep.
In terms of software… I suspect it too has its share of warts.
I don’t think you could go wrong with either unit.
While we see a couple of people complaining about their units… It seems not that wide spread. (Although YMMV) I’ve never had issues w the software or the upgrade… outside of a couple of quirks.
Thank you for your reply. I am planning to purchase RS151 and will consult with everyone if there are any usage issues.
You’re going to find out that there are issues. But this is true w any product… warts and all.
I think you are right in doing your due diligence and asking the community for input.
I’d suggest talking to your local deal.
If you don’t have a local dealer for the Rose… go with Matrix… if neither are local… find a dealer that has a decent return policy. So you can buy, try and return within their time limit.
