I just got my 130 yesterday and started to try and get familiar with the functionality.
I mostly only use tidal so not looking for too many features.
first it seems like there is no true native (tidal connect) and that the tidal app within the rose sw is limited.
Hopefully my issue with the play queue is a simple user error.
I am use to just exploring in the native tidal app for recommend  songs or playlists.
using the rose version of tidal, I was trying to add a playlist of around 17 songs.  I also tried to select another larger playlist but that kept on coming up with some errors regarding some songs are not allowed in playlists.
now when I try to listen to an new playlist that I choose, it will play the first track then skip to some other random track that is in a play queue that now shows 1032/3000 songs!
I was trying to find a way to delete all of the songs on that playlist so that I could start with just the songs I choose.
I tried to select all and delete, clear the cache but the songs still show up in the queue.
thanks for any suggestions,
jp
On the playlist screen, after clicking on the DELETE icon, then SELECT ALL button, did you press the CONFIRM button on the little popup BOX appearing AT the bottom of the screen ? AND THEN AGAIN CONFIRM on the pop up window appearing in the middle if the screen ?
If you follow these 4 steps, then your playlist will be EMPTY and the counter will then turn 0/3000…
Hope it will work for you !
Thanks for the info.  It doesn’t work on the android app but does on the screen and on the windows app.
I was hoping to avoid using the PC and not have to get up and clear on the 130 itself.
Not a big deal but I will check all 3 places when something doesn’t work the way it should.
Well… It DOES work on my Android App !
Thanks for the confirmation.  It is now also working on my android app.  I had a few lock ups on the 130 and needed to reset a few times.  Not sure what changed but at least now I can clear the queue.
Thanks again for your help.
