I started to use Roon, but can connect my music library from the hifi rose 150b. Does anyone can help me with that. Thanks
- Is your ROON Core and RS150B in same network?
- Can you find RS150B in ROON?
- Can you show me a picture where you’re stuck at?
Yes they are in the same network, Roon can see rose to play back.
I’m trying to go to settings-storage and I see the iTunes folder there, click on add new folder and it ake me for the folder location and I got stuck here.
