How to copy from NAS to Internal SSD?
Hello fellows I’m using Synology NAS and trying wirelessly to move my music over to newly installed internal Samsung SSD in RS520 but no luck. I do not have a computer so how might I do it; what are my options?
On Synology NAS you can setup a sync whereby music on your NAS is synced with the Rose internal SSD using the Synology “Cloud Sync” app. Make sure you set up a WebDAV account (username and password) on your Rose to allow your NAS to remotley login.
You will need a tablet or something to allow a web session through a browser to log into your NAS to setup the “Cloud Sync” WebDAV sync.
Had it running for around a year now - easiest way to have the internal SSD updated with any new music. Of course you will have to do a DB rescan for full search functionality on the Rose, but will have immediate access through the ROSE folders view.
e.g. For CD quality files:
  • NAS: /Music/Music Library/CD
  • ROSE: /ROSEDISK/Music Library/CD
I have folders on NAS/ROSE synced with “MQA”, “CD”, “FLAC HiRes” and have three sync tasks setup under “Cloud Sync”.
Excellent thanks I’ll set to it -
