Dear Sirs,
Please be so kind as to give me a hand with the UPNP service built-in 201E. As I’m not too fond of UPNP, I would like to turn it off.
I really appreciate any help you can provide.
Danijel
Dear Sirs,
Danijel
ROSE device cannot turn off stuffs like UPNP, airplay for now,
but obviously, I think it’s a necessary feature because it’s only used by people who use it.
We will check if we can add turning off.
Thanks for your comments.
Thank you for the clear answer.
However, I think that such network services should not be mandatory.
Danijel
