when playing some of the rosetube videos, is there any way to make it fill up the screen on the 130?
thanks,
jp
Here’s how to enter the maximum screen size you can see on RS130.
- Select Rosetube app on RS130.
 - Select the video you want to see on Rosetube.
 - The title of the video you selected will appear at the top of the RS130 screen. Please select the video title.
 - This screen is the maximum screen size you can see on RS130.
Since the RS130 screen is shorter in height than width, it is impossible to play the video horizontally to fill the entire screen.
