How to open Rose remote entire case?
I would like to open the entire case of the rose remote to remove some loose plastic inside, but do not wish to break the tightly fitting back. Is there a good procedure for doing this? I do not see any screws anywhere and it seems to be held in place by plastic tabs. This controls a 150b device.Thank you.
That’s good to know about an option for an aluminum remote. I will ask my dealer for one, thank you.
@taystnotes
You can’t open the remote yourself and remove some loose plastic inside.
You should contact the distributor in the country where you purchased the RS150b and explain your problem and get a new remote.
