Hello folks, is there a setting so that CD downloads are turned off in the correct order, for example songs from 1-13 in a row. Currently, the following order is always played with with: 1,10,11,12,13,2,3…9.
Thank you for your help.
A way to sort this out is to renumber tracks 1-9 to 01, 02, 03-09.
Thanks for the tip, I’ve already found that out. But that’s a bit annoying if you have to do it all the time with every new purchase. There must be an easier way. Any setting in the software or in the menu on the device?
