Hello, I need your help since Im unable to play Spotify on my 130 even I
m aware of Spotify connect. I want to play Spotify via ethernet and not bluetooth. My soon who is quiet familiar with this kind of stuff/installtion gave up since it seems to be rather difficult. Even the Eversolo 6 I had before had a Spotify bottom (like the one of Qobuz on the Rose). Its strange that other streamer have a suitable software/access to Spotify while Rose stated they have problems with Spotify autorisation. I scratch my head looking on the price of the Rose and the poor software. Don
t get me wrong, I like the built, screen and before all the sound of the Rose, thaT´s why I`m keeping it.
I would appreciate very much an advise how to use Spotify with the single steps to install from uses who have mastered the job.
Many thanks in advance for your help. Have a great X-Mas time Oliver
It should be really easy. I presume you have a smartphone with Spotify on it? Just have it connected to the same network as your Rose. From your app, you should be able to connect to your Rose, using the device selection option in the ‘what’s playing’ screen.
That is, if you haven’t tried this before…
Good luck!
Hello Jobbie, many thanks for your suggestion I`ll give it a try. Merry Christmas to you Oliver
Hi Oliver, a happy streaming new year for you!
Did it work for you? In case not, I was wondering if you have set the following: Parameters - Streaming - Spotify On.
Hello Jobbie, it`s very kind that you ask an take care. I tried but were not successful. Where do I have to set the “Parameters - Streaming - Spotify On”? On my mobile where Spotify is installed or in the menue of the Rose somewhere? Many thanks in advance for guiding me through that little battle - I have Spoty for almost two years now and a pretty large music library. To be frank: I like the software of Spotify far more than the Qobuz - availability of music in thw hole library, same is true for new music suggested and based on my listening through the KI of Spotify - only downside is that they have only MP3 quality of sound and this seems to be ongoing without change for decades. Anyway many thanks and enjoy your Sunday Oliver
General Informations about Spotify Connect:
Easiest way to activate Spotify Connect is the Shortcut on the device itself:
Activate over App “Settings / Streaming / Spotify”
Hello Jobbie and MuP, many thanks for your efforts and single step guidance to get Spotify ready! Ill give it a try this evening - seems to be easy if you know what to do! It
s really great if you have members who are so dedicated with help like you! With my best regards Oliver
Hello Jobbie and MuP, just to confirm that`s now working. With your guidlines it worked like a breeze! Again many thanks for your support. Best regards Oliver
Great news Oliver and I’m glad we could be of assistance!
Happy listening!
