Can anyone advice how to replace battery on the remote control of RA180 ?
I will explain how to replace the battery of RA180.
- Flip the remote control backwards as shown in the picture below.
- If you look at the bottom of the remote control, there is a cracked part in the black plastic. Use your fingers to gently pull in a downward direction.
- The RA180 remote control uses a 3V battery.
Thanks very much for the quick reply. Done replacement.
