I am unable to adjust the optical digital output on my 201E
I don’t have the option to set the optical output of the HiFi Rose 201E to “fixed”. There is no option in the menu when i click on the gear next to the optical output. On other models of HiFi Rose there are 5 lines and the 4th is “software volume control”. This does not appear on my 201E. Is there a setting that is limiting this operation?
@WoodyC
The functions in the RoseConnect app and the functions in the RS201 are not displayed the same.
However, they are not there in some places and are there in others, but if you set them up, they will be linked.
