I am using RS201, do I have to set it up separately when using headphones?
Q)
If I plug in the jack while playing, the music pauses and the meta window remains the same. If I change to the home screen, the headphone picture is activated, and if you press the play button again with the jack plugged in, sound comes out from the speaker.
For reference, I am listening to Medis 7 by connecting it with USB.
A)
In ‘IN/OUT Setting’, touch RS201 picture on the left(use internal DAC). When using an external DAC, we will improve the guide text so that there is no confusion in using the headphones.
i really would not bother its very disappointing. needs working on the headphone output. How i got round this i fed my unit into my naim amplifier.
I’m sure Rose will get it right one day other than that its pretty good
