I Got an Aluminium Remote Control for my RS150B Finally
The RS150B I bought a year ago came with a plastic remote control. I wished that it could be aluminium-made like the one that came with the RA180.
Finally I got an aluminium replacement a few days ago.
Layout-wise, the buttons on the new unit are nearly positioned the same as the plastic one. Connecting it to the original Bluetooth dongle of the plastic model has no issue too. Indeed it works flawlessly.
However, I am a little disappointed as the aluminium remote control is a bit over-size in my opinion.
See picture below, compared to the RC unit of the RA180 (left) and the original plastic RC unit of the RS150B (middle), the new aluminium unit (right) is quite large, and a little heavier too. It simply doesn’t match with the RC unit of the RA180 at all. It would be perfect if it could come in the size similar to the plastic one.
Surely, you don’t have to agree with me as it is purely my personal preference. Also, if you only have the RS150B, whether remote controls matching each other or not isn’t a concern to you as well.
Nevertheless, it is well-made. And it is in aluminium as I’ve been longing for after all. :smiley:
Where did you get the aluminium remote? And does it also work with the RS520?
It probably should, my 520 came with an Aluminum remote just like this…
Ok thanks… You got lucky. My RS520 came with the cheap black one. :unamused:.
I rarely use it anyway, controlling everything from Roon, but IMHO the black plastic one like what came with my 250 fits in the hand better anyway…
I got it from the Rose distributor. You could contact yours for details.
Totally agreed. The black plastic one is nicer in handling.
I mine never come with a remote?
How can I get one ?
Hi.
I bought Rose RS150b in Poland in Top HiFi dealer. Can I ask the dealer to change old remote which doesn’t work properly to new aluminium remote?
You can ask but I am sure you’ll have to pay for it. :wink:
@Basstech @pedro70
First, please let us know the symptoms or which part is not working.
If you simply want to receive a new remote control, additional costs will apply.
I never got a remote I brought the unit new
What are costs?
The local dealer resolved the matter positively. :grinning:
@aswiss @pedro70
Unless there are any special problems, it is difficult to receive a new remote control for free.
Please contact the distributor in your country for pricing.
@aswiss
If you look at the link below, you will see the Swiss distributor homepage.
Please contact your Swiss distributor to purchase a new remote control.
From which german dealer, you got the remote?
J’ai reçu le miens avec la télécommande aluminium je l’avais demandé avant de commander mon rs150 et il est arrivé avec selon le distributeur français ils seront bientôt tous livrés avec la télécommande aluminium.
A good reason to strongly ignore this trader.
On the other hand, it is probably not advisable to talk about such things openly because they all like to operate in protected markets. Something normal workers do not get/have, protection from cheaper competition that is.
