For a company with the high end product line that Rose has to not support Tidal Connect is silly.
They are missing the boat on a lot of easy sales.
Adopt BluOS dump the Rose app … Lets go !!!
BluOS… good Lord…
Don’t get me wrong. I don’t use BluOS to play music.
I think most people use roon or tidal connect or spotify connect.
BluOS is an alternative to roon for multiroom audio setup then you pick Tidal or spotify connect to play music.
Roon is much better for that though (albeit an additional expense) and works quite well with Rose.
Connect is OK, until the day when your babysitter blows out your speakers because her phone still tries to send to your system, and she can’t hear it from home. It’s also not at all trivial to implement apparently, and some significantly more expensive than the Rose devices don’t do it either because manufacturer decided that it is not worth the effort…
