I am hoping someone can clarify the following dialogue on the rs130 input/output settings sub menu:
I am able to play DSD512 files correctly over USB (not I2S).
The settings when using USB are Native.
the statement that " When in Native mode, analog output supports up to DSD512 when playing DSD, but digital output does not produce sound."
That seems to conflict with what I am seeing.
My goal is to try and play everything up to DSD512 via the I2S interface.
I figured out (thanks to forum members!) that the gear icon for the I2S interface seemed to be missing but you can just use the one next to the coax and it should apply to the I2S!
thanks for any help in interpreting the dialogue regarding DSD mode.
