Can I use a dvi 24+5 to hdmi cable for the I2S (dvi) to get connected to the Musician Aquarius Dac?
Thanks in advance for a your reply
Hello, it is possible to use a conversion cable. Please check the pin arrangement when using I2S output.
You can choose A or B mode.
Thank you for your answer but I am talking about the cable because there is 2 models: 24+1 and 24+5 to hdmi. Moreover we can find adapter for the 24+1 to hdmi and not for the 24+5. Which one would I use? What do you recommend?
Or where can I find the compatible cable to your diagram?
Many cables are set to mode A by default.
Also, use 24+1 to HDMI.
will normal DVI to HDMI cable works?
Yes, I have used an adapter and it works perfectly fine. On the contrary, when I used the rj45 I2S with my aqua dac it didn’t work, in spite of the confirmation given by Rose technician!
Be careful that the i2s is not a standard use in every dac. I am using now for the I2s hdmi the Laiv Harmony dac.
