Impossible to drive my external disk from Rose connect
Strange thing : since 2 weeks, perhaps after an automatic update of Rose Connect Premium, it is impossible to see on the application le content of my external Hard Disk and to enter into folders/files or navigate through the style, albums, …
Howewer, I can see the latest tracks played on the application. So, through the application, I can only choose this recents files and not all the files
I can also enter the hard disk using the screen of the RS 130 and choose by this way the files.
Is any problem/bug with this version (5.7.22 IOS 17.6.1) ? what solution ?
@Philippe
Please check if the same symptom occurs even if you try the method below.
RoseConnect app–>Settings–>Media Library–>Click DB initialization in the upper right corner, and when initialization is complete, click the storage device to scan the DB.
Everything done : no success
I still cannot find my files and folders in my music even I can play the latest files stored
It strange because I can access the files using the screen of the rs130 but not through the rose application (5.7.43)
The rose is on 4.19.01 system ( no upgrade because of all the bad comments and I really like to keep the quality of the sound)
@Philippe
This issue appears to be resolved by updating your RS130 to the latest version.
If your RS130 version is 4.19.01, it is a very old version.
And in the case of the latest version, many bugs and stability have been secured.
