Yesterday I’ve updated my RS150 to 4.15 version.
First I had to reinstall the Qobuz App (due to the new apps policy), then I was able to connect to my Qobuz account.
Today, the Qobuz app doesn’t work anymore, I couldn’t access to search engine, the Qobuz suggested songs/albums/playlists, and my songs/albums/playlists…
I decided to logout/login, and now I’m not able to login anymore, I tried to login on the RS150 unit itself, the Rose Connect App for Windows or The Rose Connect app on Android, none of them was able to login.
The Android App allows me to login, I can go the authorization page, then the App crashes and no login information is stored on the RS150.
Please fix that, High def streaming is my main using of this RS150, I absolutely need it, I’m sure I’m not the only one.
Thanks,
Christophe
