In the library, albums marked as inaccessible
Now, for the registered library, when the external hard disk or network is not connected, the album is marked as not accessible.
I hope if the album is not connected, it is suggested that it is better not to show the album, but only when it is connected.
Recently, I tried to search for music while disconnecting the external hard drive. It was impossible to check if an album that was displayed inaccessible was playable unless you went to the song selection display.
Please consider of it.
(This is an article written in the ROSE community in Korea. I have copied this article to help you understand how to use the category.)
We are also considering about what you said.
There is a disagreement as to whether it is better to make it invisible from the beginning or whether it is better to mark the contents as visible but not usable.
Due to the current database structure, it is difficult to determine whether access is possible with only the album name.
Considering your opinion, we will continue to think about a more convenient way to use it.
