Incorrect tense in error message
In Rose Connect, the error message when the wrong user name or password is entered is “You can’t logged in”. This is incorrect. It should state :“You can’t log in.”
@StandardModel
Hello, this is HiFiRose.
Currently, an error has occurred on the Rose server, and we are conducting an emergency check.
From the current time (Thursday 10:08, GMT+9), the use of the Rose server may be restricted for about an hour.
We will finish the check as quickly as possible.
We apologize for any inconvenience this may cause.
