I’ve noticed that Rose Connect will index individual tracks which contain a comma or quotation mark but when searching with the exact same name these tracks are not found. For example the track named “That’s Life” or “no one knows we’re dancing” can’t be found with the search function. Is this something that can be resolved?
If you click the 123 icon as shown in the picture below, you can see a list of special characters.
Thanks for your answer but I know how to put in a special character.
If you read my post good you can see I wrote: “but when searching with the exact same name these tracks are not found” have you tried this yet?
I understood your problem exactly.
Your problem was replicated on our side as well.
We will fix this issue as soon as possible and distribute an update.
