Inlog problemen
Hallo
Naar de update van deze week van de rosé 150
Moet ik telkens opnieuw inloggen bij
Tidal ‘em Qobuz?
@Sjonniebygood
In this update, both Tidal and Qobuz apply a new login method according to the Tidal and Qobuz request, causing the inconvenience of having to log in again.
Please delete and reinstall the Rose Connect app.
Then try logging in to Qobuz on the app.
We will identify the cause and fix it. Recently, Tidal and Qobuz have changed their usage policies, causing various inconveniences.
We will discuss with Tidal and Qobuz to fix them to avoid inconvenience
