Hi there…another question please. I have set up one of two RS-520s I just bought…but when I go to insert the Bluetooth/ Wi-Fi device/antenna, I am only able to slide it into one of the three USB ports with the antenna point DOWN or straight out.
The antenna obviously tilts, but it feels upside down. If I check out the base of the device and try to rotate it 180 degrees to get it right side up as if it would break…doesn’t seem to turn that way. Anyone dealt with this? Should I be able to turn the part that plugs in 180 degrees without breaking it?? Little help appreciated.
If you look at the picture below, you can rotate the USB with the USB and the antenna at right angles.
Thank you. I will look more closely tomorrow in the light and turn it that way.
