Hello, and thank you for the answer in the old forum. I am not sure I understand it correctly, however. My question is about this two scenarios / set-ups on the RS250:
Option 1) 4TB portable Sandisk SSD connected to the back USB 3.0 port via a USB C to USB B cable.
Option 2) 4TB internal SSD.
Which one would be best? Or would they both be the same?
