Great device:clap:t2:
I bought it in Germany. I’m completely happy. Great tube clock and VU meter. My integrated SSD also works great. Absolutely awesome piece.
I just can’t receive some streams (German radio streams for example R.SA Maxis Maximal) in 192kbps, although I can stream them without any problems on my old Pioneer N-50A. I was also in contact with R:SA and they told me: your stream is 192kbps and okay. I should contact the manufacturer. Is there a software update coming from you???
Alles selber geklärt👍🏻
