Interrupted music playback when using USB isolator Intona 7055-B
Hello everyone,
I recently started using the USB 2.0 Hi-Speed Isolator from Intona. I often get the message that my DAC (Cayin CS-100DAC) is not connected to the RS 150B. After switching the two devices on and off several times, I can listen to music again and the signal transfer from the RS 150B to the DAC is established. Does anyone have a solution to the problem. The sound reproduction is audibly better via Intona USB-ISOLATOR.
Many thanks and best regards
Reza
