- I am using an iPad Pro to stream Hi-Res apple lossless music to a Rose 150b USB DAC.
- I am using Rose 150 B as a DAC only, outputing to an analogue preamplifier via balanced output.
- I have 2 questions
- How do i know the audio signal quality. The signal path in the Rose Connect app doesn’t show any value.
- I am able to control the volume from the ipad as well. Ideally it should be greyed out with pure digital stream going to the DAC.
