iPad Settings: Media Library
What is the difference between “initialize” and “re-download database” (Datenbank erneut herunterladen)?
Can auto rescan be changed - actually every hour?
Thanks.
DB initialize : Initialize the database saved in the ROSE device. ROSE device will be rebooted after DB initialize and you will be able rescan the DB if you want.
Re-Download database : Import the DB on the device to the phone app. Sometimes there is a difference between the mobile phone DB and the device DB. You can use it at that time.
Thank you. That helps understanding the difference.
