Hello Team, I am working to integrate an RS130 into my AV system. My latest attempts is to utilize a WiFi IR blaster which is controlled by Home Assistant (HA). This way, I have a central location to switch inputs, volume, etc. The system works great but am trying to fit the RS130 into things here.
I have integrated a Wi-Fi IR blaster that integrates into HA. It has learned some of the ROSE RS130 IR commands and executes them well. The issue I have is the power toggle for turning ON/OFF the RS130.
Toggle commands are generally a nightmare for scripting and control of a unit. (Besides the power, the RS130 also toggles the Play/Pause buttons on the remote which makes it hard to control.)
A separate IR command for both ON and OFF, would be extremely helpful to keep the HA scripts I create in sync. (Toggle control for any feature is a nightmare for scripting and keeping things in sync. Also, it would greatly simplify the HA script creation.
Can you please send me the IR commands for the separate ON and OFF if they exist? If they do not, could you complement the power toggle with separate ON and OFF IR commands. This would help many people with their integrations.
