Most of my files are individual wave files. Is it possible to assign assign cover art to them individually?
Put a image file named as ‘Cover.jpg’ in the folder that your wav files are saved.
Thank you for your response. So if I have infrastructure like this:
Jazz (folder)
→ Artist 1. Wav File
→ Artist 2. Wav File
→ Artist 3 Wav File
Then all artists in these folder will share the same cover art. Unless I create a individual folder for each artist and place a Cover.jpg in that folder.
Am I correct?
That’s right. There’s no other way to put album cover via ROSE.
I guess you will have to use other PC programs to put each album cover.
