Hi, I’ve got a RS250. Is it possible to connect a turntable to the analog ground and rca inputs? My phono has an output voltage of 4.5mV. Thank you
Hello @miarosan
Yes It can be connected to a phono amplifier.
The ground on the back of the RS250 is the power ground, not the analog ground.
Thanks for your reply, the turntable has rca output and ground. But it only gives 4.5mV output. It would be about connecting the phono RCA outputs to the Rose inputs and then sending it to the amplifier through the unbalanced rca output. The rose would go between the turntable and the amp.
THE M MAGEnT OUTPUT IS ARROUND 2mV TO 5mV. standard this going into the rose input will be converted into digital signal then this is fed into the rose dac. yes it will be ok BUT the signal has gone an additional circuit called analogue digital convertor that will degrade the turntable signal
