Is the volume level setting correct?
Hi Rose,
I would like to ask whether the volume settings shown in the image for the preamp and power amplifier are correct?2025-12-06 12 54 45
@john6518
Normal operation requires the display to be in dB as shown below. Please close the PC app and reconnect to see if the same issue occurs.
DB_1208
I have received the correct reply from ROSEHAN. Regarding the dB display issue, I suspect it might be a bug in the Chinese version.
