Can the clock screen temperature be set to Fahrenheit.
I will check about it.
I would like to be able to do this too. Is this an option? Thanks
Any Progress on this option. Thanks
I can’t understand that they marketed this product to a country where they use a different units and don’t provide any options for us to change. This is very basic.
It’s added in next update, the next update will be in a week.
Thank you,
What other countries will be added?
Thanks much for addressing this modification. Will be on the look out for the update. Best regards. . . Byron
I was able to do that somewhere in settings, but can’t recall exactly where. However, although my temperature now displays in F and shows my correct location in the U.S., the scrolling Wind Speed still shows in kilometers/hr rather than miles/hr. So it is giving a mix of metric and English measurements.
Hello @Redbeemer01
The way to change the temperature unit
Rose device----Settings—Date and Time—temperature unit
Changing kilometers/hr to miles/hr or miles/h to kilometers/hr function is not available for now.
I’ll make a suggestion to the Software team.
