Is there any plan to offer upsampling to DSD natively?
It would be good to offer upsampling and conversion to DSD without the need for Roon or Audirvana, is something that might become possible?
Isn’t the Sabre DAC a Delta-Sigma implementation and does it internally anyway?
Doing PCM to DSD conversion on general-purpose CPUs is very intensive though and probably well beyond what the smartphone-class CPU in Rose can do (and does not serve any practical purpose anyway), so this is unlikely to happen.
Auralic G2 does DSD upsampling, for example, and the 130 will upsample PCM.
There is no DAC in the 130 I don’t understand your sabre reference.
Ah, for 130. I would still very much doubt it, without specialized hardware it is very intensive, unlike PCM upsampling. Not much practical reason for it either.
Not sure how ‘very intensive’ is this job, since all Lumin DAC or streamers can convert PCM to DSD128 or DSD256 on the fly !
Indeed! I used to have LUMIN before the Rose… I WISH the rose upsampled to DSD.
makes a huge difference in improvement on my T+A dac
@rolling18
Thank you for sharing your experience, and we appreciate your feedback.
We understand your interest in DSD upsampling, especially since you’ve seen a noticeable improvement on your T+A DAC when using LUMIN. Technically, DSD upsampling is possible, but implementing it requires significant processing resources and a different conversion architecture compared to PCM. Because of this, the feature is not currently available on Rose devices.
