I just got my 150B and love it. The problem I have is the feet do not come off so that I can use my IsoAcoustics feet. I have the Iso on everything in my rack. Audio Research Preamp and Amp, Sansui Tuner, Rotel CD player, ProJect DS TubeBox, Woo Audio Headphone Tube amp SRM tech TT. I mean everything has matching feet. Some larger then others but all Iso. I have placed the Iso to the left of the factory feet which looks tacky/silly/etc.
I know you can take apart the unit to unscrew the feet but Rose Does not Advice. Now this might sound CRAZY. Is it possible to use a dremel to resize the feet so that they could slide into a modified Iso foot? I know it sounds insane. If I could make the diameter of the feel 1/2 the size they would fit perfectly in a modified Iso. I have bad OCD and this is killing me…
THANKS
