Israeli weather
Can you add the options for Israeli weather and timezone ?
Is it possible to SSH into Rose and update the configuration file for URLs and parameters to set up the clock / weather ?
Meni
Would you check the streamer again?
For the weather it works, many thanks !
Fort the clock, there still isn’t Israeli time zone.
Using Athens at the moment but its daylight savings isn’t aligned with Israel
Please use Athens for Israel time zone.
About daylight saving time, Rose do not follow the time zone settings.
Daylight saving time just works with the menu : ‘Daylight saving time - ON/OFF’
So please turn the ‘Daylight saving time’ ON or OFF manually.
Best Regards,
Thanks, will give it a try.
I configured it manually and it worked until it somehow refreshed and got back to a wrong time.
I think there is a bug where setting the time manually the system will at some time override it and change the time to something automatically.
Hope those settings are planned to be made available on the Rose connect premium app as well.
thanks
Meni
