All, new app version white screens when I search for atist names. I presume this is a bug as previous version has no issues with search.
I would like to ask you to confirm a few things.
- What version of the RoseConnect app are you using?
- What is the model name of the mobile device you are using when using the RoseConnect app?
- Could you please send me a photo of the phenomenon you are experiencing?
This is not a mobile issue as stated its a windows PC issue, my android tableb works fine!
I am using app version comnnected app 5.9.7 and Rose 41 version 5.9.05.
I have a 151.
Here are pictures of the versions and the white screen that happend after a search.
I have exatly the same problem. When I go to MUSIC > FOLDER > “Enter Search Term” after typing the Group Name a blanc screen appear freezing the software functioning. To me the Search Function is is the most important feature and I think to reinstall the previous softare version (5.7).
The version with the fix for this issue is scheduled to be released soon.
Our goal is to have it distributed within this week.
Best Regards,
Thank you I can confirm 5.9.8 has resoleved the search issue.
Regards
Del
