Keyboard on RS520 not working!
While trying to enter into sections of the settings that require entering my passcode, when I attempt to type my passcode using the onscreen keyboard the keystrokes are not being sent to the input box. I have tried a reboot and that is about it.
Are you talking about your PIN? Its numeric and you can only use the numeric keypad.
@Chiefbootknocker
Please try unplugging and plugging in the power plug. If the problem persists, please send us a photo of the problem screen.
shim1691@citech.kr
@Chiefbootknocker
As mentioned by @Smegel above, is the place where you are trying to enter the password a PIN code input field?
In that field, only numeric input is allowed.
Since this has been mentioned twice I would like to clarify. My wording was not the best. The keywords were no input to the text box. When I say that I mean no numbers no letters, and no special characters. OK I get it letters and special characters are irrellevent for this application. I guess I didn’t know the software would prohibit them from even being allowed to register, but still no numbers either.
I just reset the thing.
@Chiefbootknocker
After performing a factory reset on the RS520, were you able to successfully enter numbers and set the PIN code?
Yes, once reset the input box was registering keystrokes again. I set a new numerical passcode and set all additional seetings and everything is fine.
@Chiefbootknocker
I’m glad to hear that the issue has been resolved.
If you have any additional problems or questions, please let me know.
