laregest cap of external Usb hard drive on RS520. Would 20Tb or 22Tb work?
Let me explain it clearly.
The SSD and HDD to be installed in the Rose device supports up to 4TB. However, there are times when capacity beyond that is recognized. However, the capacity that is always recognized without problems is 4TB.
The HDD or USB external hard drive you want to connect to the USB port on the rear of the Rose device supports up to 10TB. However, there are times when capacity beyond that is recognized. However, the capacity that is always recognized without problems is 10TB.
