Did you ever consider installing a small LED behind the on/off switch of the Rose 150b? My Rose is positioned on a rather dark place and I always have to switch on the lights in my room to find the exact spot.
uh no, especially no LED, I absolutely don’t want one.
take your remote control to turn it on.
……… the application also allows you to turn it on
I know, I know! But my remote is not working (just blinking!) and mostly I want to handle the machine just by using the touchscreen, it’s not that sophisticated for nothing?
We apologize for any inconvenience caused. Have you connected RS150b and remote control via Bluetooth? If you are not connected, please check the link below.
Thanks, I now can at least control my Rose with the remote.
But nevertheless I like controlling it “with my finger”………
