LG C3 oled tv shuts down after 15-20 minutes connected to 150b through hdmi
Looking for help, My LG Oled tv shuts off after 15-20 minutes. I am watching Rosetube from my 150b using the Hdmi output. I get picture on my Oled tv but after 15-20 minutes it turns off completely and goes into standby. TV sleep timer is off , I am not using any power saving settings. 150B is connected to my hdmi 4 on tv. I do have a sound bar connected to hdmi 1 and a DVD player on hdmi 3. Also a roku tv stick on hdmi 2. My picture from my 150b to tv is perfect, I’ve even set the resolution to 1080p to see if that made a difference. It did not help. My dvd player has no issues or my roku stick, only my 150 b !
If someone has a solution other than using different hdmi cables, switching hdmi inputs, or resetting the 150b to factory default , or deleting the app I would surely want to hear your advice.
Thanks in advance!
@Scareface1
At the moment, we have not been able to reproduce or confirm this issue on our side.
I will summarize your symptoms and forward them to our software team.
As soon as we receive feedback from them, I will inform you right away.
@Scareface1
To confirm whether the issue only occurs when connecting the RS150B to the TV, do not connect any other devices, connect only the RS150 to the LG TV, and check if the issue occurs when playing RoseTube.
