Hi there,
Can anyone help me find the list of errors on radio ?! I encounter many errors on the radio and I don’t know how what is the problem. Today the radio its working, later do not work, not so happy with the radio…
Nothing?! No one with issue…?!
You need to calm down pal.
Hi PwR,
i’m new to ROSE RS201E an hav the same experience as you. Seems to me there’s a lot of bugs to the Rose-Radio.
Hopefully time will tell…
Ouu, but im calm, only frustrated. I used a old wxc Yamaha and im not used to have this bugs. In 10 sec from startup i lisen music. Now… It take me 3 minutes, and i do not know if, i have a problem, or Rose have problems. …
Yes, i just want to know what this errors are.
It seems we have a solution. We made some “trial and error action”. Use the Rose-App on your Smartphone > “Radio”.
There are >Favorits, / your Country /add user channel (sorry, translated from german).
By adding a user channel you are able to name and set the URL by copy/paste.
Some Stations now working even with https!!
I will spend some more time on this.
This its my problem…
I lisen this morning one radio station, and if i want to lisen now, i have this error. If i retry after 1 or 2 hours its working. If not, i have to search againt the radio station and add to fav. AGAIN.
I do not undetstand, why…
I’m sorry about the radio channel.
If you can tell me the region you tried, I will review the channels. (ex- GERMANY)
Absolut relax (germany)
Its apear like 3 diferent radio station but its only one. Today blue its working, tomorow green, after tomorow none its working and so on…
Hello, We are checking this Radio Channel, and we can also see Red is working now and others are not streamed. For now, it looks the policy of this radio channel. It seems to be changing the stream URL dynamically. If so, it may be difficult to actively respond unless we create a separate program that can track the changing URL of this radio channel. We’ll also watch the STREAMING URL change for a few days.
