Love my RS 250 its fast becoming a digital hub for me, I wonder if we could have more detailed weather zones.?
If you tell us the region of the country you want to add, we will add the region that can be added.
I was hoping to get more cities in the UK
Also here in Germany, it will be nice to have (for me) also smaller cities like Diessen am Ammersee, Albstadt or Sigmaringen…
Please specify which city you would like to add. However, cities that are too small can be difficult to add. After we check the city you wrote down, we will add those that can be added.
Thanks for adding the new cities!
Hi, can you ad also Ljubljana / Slovenia?
Hi, could you please add Haugesund / Norway
Yes, Haugesund is added.
Thank you for your quick response
Hi, Roseloa
Thanks for fast reply, but still there is no weather site for Ljubljana / Slovenia.
Or is there something I have to do? Any update on my rs250?
Regards
Filip
Any chance to add Halifax, Nova Scotia Canada?
Hello.
Kopervik / Norway would be great if you could add, thanks.
I’m sorry to tell you.
Kopervik is currently marked as an unavailable region on our servers.
If you tell us another region, we will check it and add it.
Yeesss. Thanks.
Could you please add Zwolle in The Netherlands?
