Localized Weather Request
@Bussi
I have completed adding the requested regions of Warburg and Paderborn in Germany.
However, for Borgentreich, it has been confirmed that this region is not supported by our server, so I was unable to add it.
Hi Rosehan,
Would it be possible to have Norwich, UK added to the weather locations please
Many thanks in advance
@Floxus
I have completed adding the requested regions of Norwich, UK.
Hello can you add either Canton Ohio or if you can’t add that Cleveland OH to the weather ?
@Johnprod
As you requested, I have added the Canton and Cleveland areas in Ohio.
Hi Rosehan!
Is ist possible, to add Lüneburg / Lueneburg ? Germany.
Best regards
@Herr.moe
As you requested, I have added the Lüneburg in Germany.
Hi Rosehan! Thank you very much - more Perfect now.
Hi Rosehan!
Is ist possible, to add Piotrków Trybunalski/Poland.
Best regards
@pawiz1
As you requested, I have added Piotrków Trybunalski/Poland.
If you reboot your Rose device, the region you selected should appear.
Is it possible to add Wyk, Germany or Flensburg, Germany? Or better „Foehr“, Germany? Foehr would be perfect …
Thanks and best regards,
Frank
@FrankP
I have searched for Wyk, Flensburg, and Föhr in Germany, but the only region supported by our server is Flensburg, Germany.
As you requested, I have added Flensburg, Germany.
If you reboot your Rose device, the selected region should appear.
Perfect! Thank you very much. Flensburg is only about 50 km away from the island of Föhr as the crow flies. That’s just about right…
@FrankP
If you would like to add additional regions, please let me know.
