Recently, I moved all of my Apple Music files to my RS250A. Since then, songs take much longer to start. Could it be that the volume of file are slowing the hard drive and is there a way that I can decrease the buffering between songs?
Please check a few things.
- Did you transfer Apple Music music to SSD or USB external hard drive and then connect it to RS250?
- Did you log in to your Apple Music account on RS250 and link your existing Apple Music music?
Doing both of the above will not slow down the device.
Try factory resetting your RS250.
RS250–>Settings–>system settings–>Factory reset
